EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
BUG after updating of Fusion360. Error pushing to fusion: .
3 REPLIES 3
4ckatro
231 Views, 3 Replies
I have a returning issue about pushing design to Fusion360 from Eagle. I could use successfully the push to fusion option like 40 times on this design. But now after applying plenty of modifications on the board I got an error. I am working on a complex design and I cannot share the design files. However the error message does not help me to figure out what is the problem. There is a similar post in the forum, but it is abandoned, other user reported this issue is really annoying and no one bat an eye...
So I get the error: "Error pushing to Fusion: . "
But I do not know where to start to find the error. As I mentioned, the design is pretty complex, with ~500 components, all of them are having 3D models.
If I remove the fusion link and create a new one I got the same error. If I try to push two times, in the second try I get another nonsense error:
Where can I check what causes the problem?
Any help would be welcomed.
Rob
UPDATE:
I deleted everything from schematic and layout, removed fusion link, created new fusion 360 design  and still same error:
UPDATE 2:
I opened a second project, where I didnt do any modification and pushing does not work... Same error. So probably after applying an update to Fusion this feature got broken on my case...
3 REPLIES 3
jorge_garcia
in reply to: 4ckatro
Hi @4ckatro,
I hope you're doing well. This should be working again, please try it and let me know if you still have problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
4ckatro
in reply to: jorge_garcia
Yes, it is working now. Could you please extend the error message? If it was related some server issue, or some internal stuff it would be nice if we get an explanatory message. I spent half a day, to figure out what is the problem with my design... It would be much straight forward with an extended error message.
Thank you!
Rob
jorge_garcia
Hello Rob,
Thanks for the feedback.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
