Bottom layer's connections not visible
i have designed a PCB for my project. I am using 2 layers and have connections in both the layers as in the first picture.
Now when I added the ground layers I am able to see only one connection on the bottom layer. The remaining connections are not routed. Why is this so?? It is looking at something as below. Is it because I routed the other bottom connections to the ground?
With groud poursWith groud pours
jorge_garcia
Hi @testeurs234,
I hope you're doing well. Since those bottom traces are GND connections that polygon will swallow them and this is OK. It's actually a good idea to do this since if further routing breaks the polygons then the connections are still preserved.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thank you Soo much. As this is my first board on RF I'm skeptical about my connections and all.  I would like to know your reviews or suggestions about my design. And can you even suggest me whether I have to take care about the width of the trace connecting the IC and Antenna? Suggestions are much appreciated. Thanks in advance.
