EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Board Size Limitation for original CadSoft Eagle
1 REPLY 1
rigustafson
239 Views, 1 Reply
I had the original CadSoft Eagle program before it was purchased by Autodesk. I thought I read somewhere that as an original user, I would retain certain access rights. However, now I can't make a board bigger than 80 cm2. Am I wrong? Do I need to get a subscription now?
1 REPLY 1
jorge_garcia
in reply to: rigustafson
Hi @rigustafson,
I hope you're doing well. As an original EAGLE user you preserve your original eagle license up to whatever the last release of that version was. You can use that forever, after V8 of EAGLE and moving into Fusion 360 you will need a subscription moving forward.
Let me know if you need any further clarification.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
