EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Board fault Eagle push to Fusion
1 REPLY 1
ErikvWijck
266 Views, 1 Reply
If we export the design to fusion by pressing the push to fusion button, we see the complete design with a small section of the board.
See pictures in attachment
We only get to see the board with the orange line around, the part with the green line is missing
After deleting all components, the problem is still there.
See our outline .brd in the attachment.
What could be the problem?
1 REPLY 1
mtl_asm
in reply to: ErikvWijck
hi
im not sure if this is the issue but if you move the line that is the bottom of the board outline you can see you have a sort of double line on the bottom. here i just dragged down the bottom edge and you can see the dimension line stub. maybe try deleting that and importing again. it seems to be correlated with the base of the orange triangle.
there is another one here
i attached the .brd with those deleted but i did not test pushing to fusion.
