If a net has a polygon, the autorouter ignores it. This makes sense if you are using ground and supply planes in a 4 layer board. Unfortunately, this logic does not work when a polygon in not covering the entire board, or is on a layer that is shared with other traces
Currently my workaround is to rename the polygons before autorouting, then name them back afterwards. Tedious and clumsy. Is there another way of doing this, or can we request that the autorouter should not always ignore nets with polygons (and perhaps have an option to choose) ?
Hi Lazarus,
I hope you're doing well. This is a first for me. If a polygon is being used as a thick trace or something like that it would still define the connection and absorb the airwires as expected. I'm having trouble identifying the use case and why you would need to rename anything before running the autorouter.
Could you describe exactly what you are trying to do? That will help me understand the need and then we can address it.
OK -- here is a couple example of how this affects me...daily....
1. I create a 2 layer board and add a ground and vcc polygon that matches the size of the board.
2. Autoroute it to "100%" ...
3. vcc and ground are not routed, and the polygons often become fragmented from other nets crisscrossing everywhere. OK, that's expected for a two layer board with planes and any complexity....but now I have unrouted / incomplete ground and vcc nets 😞
4. if the gaps are minor, I can manually route them, adjust via positions to maintain the copper pour continuity, etc. (it would be nice if the autorouter could position vias to avoid cutting off a copper pour unnecessarily)
HOWEVER
If I rename my polygons before autorouting, then vcc and gnd get completely routed. Often I'll route them with a pretty thin net class. Then I can switch the polygon net names back and the cooper pour fills in the spaces ( and the routed traces guarantee contiguity). Then I have a board that is really 100% routed, and has poured copper to maximize vcc and gnd coverage / heat dispersion (even if some sections are thinly connected islands, the connections are usually short)
Another, related example:
Lets say I've got some high power n channel mosfets and they need a lot of copper for high current capacity. But not every component that connects to ground is high current. Basically, not every segment of the a net needs to be the same width. But split nets aren't supported. So.....I've got a couple workarounds, with different problems:
1. I have to set the fat trace widths (ie: 15-50mil) in the net classes dialog, autoroute but select only those nets. After autorouting, I rip up all the fat traces that don't need to be fat. Then I go back and switch the net classes back to a thin width and autoroute again, this time creating thin traces for the rest of the net. If I have to rip up, I often have to start all over or (tediously) rip up selectively so I don't lose manually routed traces or the fat ones (if I could LOCK a trace to prevent rip up...)
2. Use a polygon that overlaps a thinner trace in the critical area. This option usually works best for REALLY fat traces, like 50-150mil. I can manually route them, but adding a copper pour optimizes / maximizes copper area for the trace. But then there is more to the net than just that high current section--like an LED, connection to a sense resistor, or a test pad. The autorouter refuses to route anything with polygon attached (unless I rename the polygons first, which is tedious when you have many of them on a board)
3. Split the net using a fake part like a "short" -- basically two pins in schematic and two small, touching smd pads in board. The problem then is this confuses ERC/DRC checks, the shorts need to be manually placed which creates artificial connections restrictions to autorouting. Also, I can only assign one net to a polygon pour, so this trick doesn't work with nets that need heat sinking in more than one area.
If there is a fourth way to accomplish this, I'd like to hear.
The autorouter clearly CAN route nets with polygons, it incorrectly assumes it doesn't have to.
