This is my first time using Eagle.
Initially the autorouter appeared to work well, but I have made many changes to the circuit. The board and schematic are consistent, but now the autorouter never finishes. I have 373 errors, mostly overlaps, but also airwires and old tracks left on the board, as well as clearances and restrictions.
Can I delete the old routing, without deleting the placement of the parts?
Eagle 9.5.0
Linux Mint 17.2
Solved by rachaelATWH4. Go to Solution.
Use the selection filter to restrict your group selection to just wires / vias and the layers the autorouter is using and then group select everything and do a group rip-up.
Best Regards,
Rachael
