Autodesk Eagle 9.4.1 (and versions before) infinite error loop, see video below:
After pressing the delete key on my keyboard instead of using the ripup function to delete a selection of a trace. This error occurred. The only solution to stop this error was to shutdown eagle completely. With the obvious result of losing any work you haven't saved already.
I don't know if something can be done about this bug, and if I am the only one who has encountered it, but I wanted to let you know this error can occur, and can be quite irritating.
Luckily I save my work quite often so I haven't lost loads of work. But it has happened to me several times in the past year or so.
