Autodesk Eagle 9.4.1 PCB editor infinite error loop.
jorick.dewit
jorick.dewit
Autodesk Eagle 9.4.1 (and versions before) infinite error loop, see video below:
After pressing the delete key on my keyboard instead of using the ripup function to delete a selection of a trace. This error occurred. The only solution to stop this error was to shutdown eagle completely. With the obvious result of losing any work you haven't saved already.
I don't know if something can be done about this bug, and if I am the only one who has encountered it, but I wanted to let you know this error can occur, and can be quite irritating.
Luckily I save my work quite often so I haven't lost loads of work. But it has happened to me several times in the past year or so.
edwin.robledo
Hi jorick.dewit,
Thank you for using the Autodesk EAGLE forum.  Today EAGLE v9.4.2 has been released, can you please try this latest version and let us know if you can reproduce the issue you described.
Best Regards,
Ed
Edwin Robledo
Tech Marketing Manager
jorick.dewit
Hi edwin.robledo
Thank you for your reply. I have just upgraded to 9.4.2 and tried to reproduce the issue. Luckily without success at this time. So it seems that the update to 9.4.2 solves the problem.
I will try to reproduce the error in the time ahead but as far as I can see now the issue is solved.
Thank you and best regards,
Jorick
