EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Arrange LEDs in circles?
2 REPLIES 2
andrzej23050
817 Views, 2 Replies
Hello.
I'm designing an RGB LED lamp made out of 80 LEDs. For now, I laid out the LEDs like that:
And I'm pretty happy with the amount of LEDs per each circle.
But now I want to more precisely arrange each of the circles, i.e. I want the distance between LEDs in the given circle to be roughly the same.
How can I achieve that?
I know that this is possible with the draw command, but it doesn't let me specify a range of elements, only the first element instead, that means that I would need to delete all the LEDs besides the ones that I want in particular circle, and then gradually add them when laying out the next circle. I don't really want to do that, that's why I'm asking is there any simpler solution.
2 REPLIES 2
C.Nicks
in reply to: andrzej23050
There is an older ulp that assists with component array placements that I have made some enhancements to. It allows easy placement of circular and rectangular arrays.
The options I added allow defining the direction the components point, plus additional rotation. This is especially handy when working with surface mount directional parts.
Circular array with additional rotation offsetCircular array with additional rotation offset
Best Regards,
Cameron
Eagle Library Resources
