Hi Philip,
I'm glad to hear it's working for you now 🙂
@Anonymous wrote:
Hi Rachael -
I suspect the problem may be something to do with the fact that one of the first things I did after installing Eagle was to change all the default directories from $HOME\EAGLE to $HOME\Dev\EAGLE - I hate things that clutter your home directory. However, I then found I still had an EAGLE folder in my home directory, so I deleted it. But rather than moving my EAGLE directory I think it maybe just created a link as I then found my Dev\EAGLE had gone too!
It's fine to have an alternative directory setup. I had mine all configured to be working in my own specified location long before it was the default official way built into EAGLE so my configuration is also totally different to the standard setup. Just make sure all your paths are accurate and you have moved everything over, if you have duplicates it can get messy.
@Anonymous wrote:
I can't find a Spice model for the LM4880 but I'm not really interested in simulating that as that part of the circuit is straight out of the datasheet. I might just make a subcircuit with 100M resistors from all pins to ground, or if I'm sufficiently caffeinated I might create a basic subcircuit with a couple of opamps. The audio jacks I'll model with resistors, and maybe the input one will include my signal source, but I'm not sure about the USB socket or power pads - one or other I can make the power source.
It seems like you have it all in hand. Anything non-critical that you can't find an obvious model for, just model it with high value resistance placed sensibly so it's effectively OC.
@Anonymous wrote:
When you mentioned the implied power pins for the quad opamps, the schematic just had one set for the 4 opamps - do I have to do something for the other 3 to get Spice power to them?
I must have missed the connections on the one symbol they appear on. If they're connected up to actual power rails on one of the device parts that's fine. I didn't realise they were all gates within the one part.
Good luck with your simulation!
Best Regards,
Rachael
