- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using several libraries provided by Library.io that only provide the basic generated 3d models (e.g. a Wurth Elektronik lbr containing Terminal Blocks).
I am able to fork and apply a custom 3D package in the board editor for a single instance of a device. However there seems to be no sensible way to apply the same 3D package to all the same devices on the board at once. I can not imagine having to replace all the devices manually one by one after finishing the board design.
In my attempt to work around the problem by creating a privately managed copy of the public managed library there seems to be no way to simply replace all the used parts form an entire library. The current option is to manually update each device in the schematic editor… Which is extremely time consuming and error prone if you ever want to switch from source library.
An additional great feature would be in my opinion to be able to fork a public library, add modifications (e.g. add a new 3d package) to the library and create a pull request to the maintainer in a similar fashion to that of software development on e.g. Github. This way we can all benefit from up to date libraries.
So my question for now, is there currently any way to replace(or override) the 3D package of an existing design for multiple instances of the same device in a reasonable way?
