My neck is hurting a bit, I have a slipped spinal disk... is that what you call it?
I do not see your point: use library downloaded from the fu---ing component manufacturer is now WRONG? No, it is not easy to draw very irregularly placed pads on the new SMDs. The drawings are insane.
Or libraries from EAGLE, using them should be wrong? You say it is hard to verify the downloaded component, which is what I said, that it can be made easy, I want to be the pins and pads highlighted, just like when you use board and schematics. I could even turn on/off airwires between those two. But you say it is easier to make one from scratch and connect things like P$36 to IN17AB, P$35 to REF16Z, P$34 to GND13, etc, etc in "the dialog box ofthe mappings" and not do a mistake rather than downloadig the original and verify that one...
The datasheets have usually very detailed visual representation of the pins/pads, with carefully placed pin numbers and labels on the depicted package variant. Make one in eagle and you can easily compare. Currently only way to compare is to actually place the part in the LAYOUT and connect it, which is how I discovered the mistake, I remembered the symmetrical connection which was not appearing in the layout...
The problem is: I want to use Eagle easily! I take Packages supplied with some components in Eagle, which are the right ones, I use symbols from another one, and I want to connect them VISUALLY, because I simply can't be sure about the numbering. Or: parts like NPN transistor having pins named xyz1, xyz2, xyz3. Which one of those is the EMITTER? Why can't I confirm or connect it visually? Heck, I could do almost identical task in a computer game made in 1994! They had less programmers than Cadsoft. It was in 3D.
I'm an independent contractor, time reading the manual is totally wasted and won't be compensated, my loss. A billion of chinese is in the same situaton. 😛
"I pick and choose what I read to learn important information."
So do I. But I keep forgetting the usage points that are so anti-intuitive that its impossible not to forget them. When I have the MOVE selected and I press Ctrl, does a Tooltip with "Right click to pick up and drag group" appear? In common software today, such features are common.
The thing with todays employment style is, that someone like me will be using Eagle very intensively for a few months and then stop for a year(s), busy with other tasks. Autodesk used to be actually famous that with a new version of Autocad, you needed a completely new training. Current fractured or multi-field work style needs tools that are useable intermittently by groups of untrained individuals, who will use it once, and then again in a few years. An electronics company that used to employ 3 to 5 thousand people currently employs ZERO people in product development, research, marketing. The two of us are independent contractors due to a variety of reasons, one of them is that the skeleton of a company no longer can afford employing people, but at least they are able to pay for results. I do the work of 5 people, and you want me to read the manuals that five people would read. I'd rather spend the time working on electron beam cathode and grid/focus system, then wood bandsaw, then my cars. It's 23:55, I had no real lunch or breakfast or dinner, no time for real human contact either. And instead of trying to put in some time into those areas, I should go and read the manual for Eagle? Nah, I have a lot of STM32 manual reading already. Currently, using it 90% efficiently with the knowledge I have beats the loss of time; there are still so many features which don't work correctly anyway...
In 3 years I forgot literally everything about Eurocircuits design rules, what it does, how it works, for example. Make that 2.5 years.
*All I want is a symbol wizard, then; pick up a package from a list, connect and visually confirm by highlighting pins/pads.*
*Eagle shall know and recognize several thousands cross-referenced package names. It needs to be done only once and verified once.*
Package names explanation: https://www.hobbielektronika.hu/forum/getfile.php?id=272088
Rachael, that is what I meant with "why keep reinventing the wheel".
How hard is that in 2017? KiCad users will buy Eagle licenses to use that functionality.
huh, by now, I not only see that Rachael is just another version of me, but actually a younger version of me. When did I get so old?
