Hello, while creating a 3D model for a diode with a DO-41 case, I had a problem. I can't specify the distance between the legs of the diode. I change the length of the pins and update the 3D body but nothing changes.
Solved by manuj.kalaimani. Go to Solution.
Solved by Yura.Ivanov.VLuki. Go to Solution.
Hello Zendilor,
Thanks for bringing up this issue on Forum!
The issue is fixed and now the "Override Pin Pitch" parameter is working for the 3D model as well(according to the footprint).
Hello Zendilor,
