Transfer Eagle 7.7 to new computer
gschwartzKBV59
Observer Observer
gschwartzKBV59
Observer
Observer
I have been using Eagle 7.7 since 2016.  I am setting up a new computer and I would like to transfer my license from the old computer to the new computer.
The problem is that I no longer have the license.key file or the installation code.
Is there any way to transfer my license from old to new?
jorge_garcia
Hi @gschwartzKBV59 ,
I hope you're doing well. I've sent you a DM.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
gschwartzKBV59
Observer
Observer
Hello again Jorge,
I have managed to find the license.key files which I pulled off of an old computer.
The "Standard" license worked fine using the original key code and installation code of "xskbsdftea"
which installed perfectly.  But this is only a "Standard" installation with layer limitation (6) and
board size limitations.
We upgraded our license to "Ultimate" and I also have a key file for the Ultimate version, but the
installation code of "kuxumodkxl" does not work.
I remember you saying that you "could" get me the installation code but NOT the license file.
Is it possible for you to find the installation code for the Ultimate license I now have"
jorge_garcia
I hope you're doing well. It looks like you have a typo in the installation code. It should be
"kuxumodkzl"
Let me know if this takes care of it for you. Like I always recommend, make sure to keep these credentials in a safe place for future use.
Best Regards,
Jorge Garcia
gschwartzKBV59
Observer
Observer
Hi Jorge,
Yes, yes, yes.....the corrected installation code worked.
Thank you, thank you, thank you.
Everything is working fine now.
Greg Schwartz
