TI Spice opamp model does not work in NGSpice,
Dear all,
when trying to assign a TI Spice opamp model for simulation, I find  an issue:
1) Load the opamp model and save the .lib file as .mdl is working fine
2) When trying to assign the Spice model to the device , it does not accept the terms G1, GVO+ and GVO- (full mdl file below).
3) When deleting expressions , containing a.m. elements, the model is accepted, pins can bes assigned. But the subsequent simulation is failing due to "fatal internal error: free_tree". Maybe caused by the deleted elements?
Thanks for your suggestions
Frank
* OPA1641
* (C) Copyright 2018 Texas Instruments Incorporated. All rights reserved.
** This model is designed as an aid for customers of Texas Instruments.
** TI and its licensors and suppliers make no warranties, either expressed
** or implied, with respect to this model, including the warranties of
** merchantability or fitness for a particular purpose. The model is
** provided solely on an "as is" basis. The entire risk as to its quality
** and performance is with the customer
* This model is subject to change without notice. Texas Instruments
* Incorporated is not responsible for updating this model.
** Released by: Online Design Tools, Texas Instruments Inc.
* Part: OPA1641
* Date: 08FEB2019
* Model Type: Generic (suitable for all analysis types)
* EVM Order Number: N/A
* EVM Users Guide: N/A
* Datasheet: SBOS484D -DECEMBER 2009-REVISED APRIL 2016
* Created with Green-Williams-Lis Op Amp Macro-model Architecture
* Model Version: Final 1.1
* Updates:
* Final 1.1
* Added Unique subckt name, removed Claw ABS.
* Simplified subckt for current noise.
* Final 1.0
* Release to Web.
* Model Usage Notes:
* 1. The following parameters are modeled:
* OPEN-LOOP GAIN AND PHASE VS. FREQUENCY WITH RL, CL EFFECTS (Aol)
* UNITY GAIN BANDWIDTH (GBW)
* INPUT COMMON-MODE REJECTION RATIO VS. FREQUENCY (CMRR)
* POWER SUPPLY REJECTION RATIO VS. FREQUENCY (PSRR)
* DIFFERENTIAL INPUT IMPEDANCE (Zid)
* COMMON-MODE INPUT IMPEDANCE (Zic)
* OPEN-LOOP OUTPUT IMPEDANCE VS. FREQUENCY (Zo)
* OUTPUT CURRENT THROUGH THE SUPPLY (Iout)
* INPUT VOLTAGE NOISE DENSITY VS. FREQUENCY (en)
* INPUT CURRENT NOISE DENSITY VS. FREQUENCY (in)
* OUTPUT VOLTAGE SWING vs. OUTPUT CURRENT (Vo)
* SHORT-CIRCUIT OUTPUT CURRENT (Isc)
* QUIESCENT CURRENT (Iq)
* SETTLING TIME VS. CAPACITIVE LOAD (ts)
* SLEW RATE (SR)
* SMALL SIGNAL OVERSHOOT VS. CAPACITIVE LOAD
* LARGE SIGNAL RESPONSE
* OVERLOAD RECOVERY TIME (tor)
* INPUT BIAS CURRENT (Ib)
* INPUT OFFSET CURRENT (Ios)
* INPUT OFFSET VOLTAGE (Vos)
* INPUT COMMON-MODE VOLTAGE RANGE (Vcm)
* INPUT OFFSET VOLTAGE VS. INPUT COMMON-MODE VOLTAGE (Vos vs. Vcm)
* INPUT/OUTPUT ESD CELLS (ESDin, ESDout)
* 2. Model represent the device operating at room temperature only. No temperature dependency is modeled
.subckt OPA1641 IN+ IN- VCC VEE OUT
.model R_NOISELESS RES (TCE=0 T_ABS=-273.15)
I_OS ESDn MID 4e-12
I_B 30 MID 2e-12
V_GRp 45 MID 56
V_GRn 46 MID -55
V_ISCp 39 MID 36.5994
V_ISCn 40 MID -28.98
V_ORn 38 VCLP -11.9328
V11 44 37 0
V_ORp 36 VCLP 11.8605
V12 43 35 0
V4 27 OUT 0
VCM_MIN 67 VEE_B -0.1
VCM_MAX 68 VCC_B -3.5
I_Q VCC VEE 0.0018
V_OS 75 30 0.000995
XU5 ESDp ESDn VCC VEE ESD_0_OPA1641
XU4 19 ESDp MID PSRR_CMRR_0_OPA1641
XU3 20 VEE_B MID PSRR_CMRR_1_OPA1641
XU2 21 VCC_B MID PSRR_CMRR_2_OPA1641
XU1 23 22 CLAMP VSENSE CLAW_CLAMP CL_CLAMP 24 26 27 MID AOL_ZO_0_OPA1641
C28 31 MID 1P
R77 32 31 R_NOISELESS 100
C27 33 MID 1P
R76 34 33 R_NOISELESS 100
R75 MID 35 R_NOISELESS 1
GVCCS8 35 MID 36 MID -1
R74 37 MID R_NOISELESS 1
GVCCS7 37 MID 38 MID -1
Xi_nn ESDn MID FEMT_0_OPA1641
Xi_np MID 30 FEMT_0_OPA1641
Xe_n ESDp 30 VNSE_0_OPA1641
XIQPos VIMON MID MID VCC VCCS_LIMIT_IQ_0_OPA1641
XIQNeg MID VIMON VEE MID VCCS_LIMIT_IQ_0_OPA1641
C_DIFF ESDp ESDn 8e-12
XCL_AMP 39 40 VIMON MID 41 42 CLAMP_AMP_LO_0_OPA1641
SOR_SWp CLAMP 43 CLAMP 43 S_VSWITCH_1
SOR_SWn 44 CLAMP 44 CLAMP S_VSWITCH_1
XGR_AMP 45 46 47 MID 48 49 CLAMP_AMP_HI_0_OPA1641
R39 45 MID R_NOISELESS 1T
R37 46 MID R_NOISELESS 1T
R42 VSENSE 47 R_NOISELESS 1M
C19 47 MID 1F
R38 48 MID R_NOISELESS 1
R36 MID 49 R_NOISELESS 1
R40 48 50 R_NOISELESS 1M
R41 49 51 R_NOISELESS 1M
C17 50 MID 1F
C18 MID 51 1F
XGR_SRC 50 51 CLAMP MID VCCS_LIM_GR_0_OPA1641
R21 41 MID R_NOISELESS 1
R20 MID 42 R_NOISELESS 1
R29 41 52 R_NOISELESS 1M
R30 42 53 R_NOISELESS 1M
C9 52 MID 1F
C8 MID 53 1F
XCL_SRC 52 53 CL_CLAMP MID VCCS_LIM_4_0_OPA1641
R22 39 MID R_NOISELESS 1T
R19 MID 40 R_NOISELESS 1T
XCLAWp VIMON MID 54 VCC_B VCCS_LIM_CLAW+_0_OPA1641
XCLAWn MID VIMON VEE_B 55 VCCS_LIM_CLAW-_0_OPA1641
R12 54 VCC_B R_NOISELESS 1K
R16 54 56 R_NOISELESS 1M
R13 VEE_B 55 R_NOISELESS 1K
R17 57 55 R_NOISELESS 1M
C6 57 MID 1F
C5 MID 56 1F
G2 VCC_CLP MID 56 MID -1M
R15 VCC_CLP MID R_NOISELESS 1K
G3 VEE_CLP MID 57 MID -1M
R14 MID VEE_CLP R_NOISELESS 1K
XCLAW_AMP VCC_CLP VEE_CLP VOUT_S MID 58 59 CLAMP_AMP_LO_0_OPA1641
R26 VCC_CLP MID R_NOISELESS 1T
R23 VEE_CLP MID R_NOISELESS 1T
R25 58 MID R_NOISELESS 1
R24 MID 59 R_NOISELESS 1
R27 58 60 R_NOISELESS 1M
R28 59 61 R_NOISELESS 1M
C11 60 MID 1F
C10 MID 61 1F
XCLAW_SRC 60 61 CLAW_CLAMP MID VCCS_LIM_3_0_OPA1641
H2 34 MID V11 -1
H3 32 MID V12 1
C12 SW_OL MID 100P
R32 62 SW_OL R_NOISELESS 100
R31 62 MID R_NOISELESS 1
XOL_SENSE MID 62 33 31 OL_SENSE_0_OPA1641
S1 24 26 SW_OL MID S_VSWITCH_3
H1 63 MID V4 1K
S7 VEE OUT VEE OUT S_VSWITCH_4
S6 OUT VCC OUT VCC S_VSWITCH_4
R11 MID 64 R_NOISELESS 1T
R18 64 VOUT_S R_NOISELESS 100
C7 VOUT_S MID 1N
E5 64 MID OUT MID 1
C13 VIMON MID 1N
R33 63 VIMON R_NOISELESS 100
R10 MID 63 R_NOISELESS 1T
R47 65 VCLP R_NOISELESS 100
C24 VCLP MID 100P
E4 65 MID CL_CLAMP MID 1
C4 23 MID 1F
R9 23 66 R_NOISELESS 1M
R7 MID 67 R_NOISELESS 1T
R6 68 MID R_NOISELESS 1T
R8 MID 66 R_NOISELESS 1
XVCM_CLAMP 69 MID 66 MID 68 67 VCCS_EXT_LIM_0_OPA1641
E1 MID 0 70 0 1
R89 VEE_B 0 R_NOISELESS 1
R5 71 VEE_B R_NOISELESS 1M
C3 71 0 1F
R60 70 71 R_NOISELESS 1MEG
C1 70 0 1
R3 70 0 R_NOISELESS 1T
R59 72 70 R_NOISELESS 1MEG
C2 72 0 1F
R4 VCC_B 72 R_NOISELESS 1M
R88 VCC_B 0 R_NOISELESS 1
G17 VEE_B 0 VEE 0 -1
G16 VCC_B 0 VCC 0 -1
R_PSR 73 69 R_NOISELESS 1K
G_PSR 69 73 21 20 -1M
R2 22 ESDn R_NOISELESS 1M
R1 73 74 R_NOISELESS 1M
R_CMR 75 74 R_NOISELESS 1K
G_CMR 74 75 19 MID -1M
C_CMn ESDn MID 6e-12
C_CMp MID ESDp 6e-12
R53 ESDn MID R_NOISELESS 1T
R52 MID ESDp R_NOISELESS 1T
R35 IN- ESDn R_NOISELESS 10M
R34 IN+ ESDp R_NOISELESS 10M
.MODEL S_VSWITCH_1 VSWITCH (RON=10e-3 ROFF=1e9 VON=10e-3 VOFF=0)
.MODEL S_VSWITCH_3 VSWITCH (RON=1e-3 ROFF=1e9 VON=900e-3 VOFF=800e-3)
.MODEL S_VSWITCH_4 VSWITCH (RON=50 ROFF=1e12 VON=500e-3 VOFF=450e-3)
.ENDS OPA1641
.SUBCKT ESD_0_OPA1641 ESDp ESDn VCC VEE
S2 ESDn VCC ESDn VCC S_VSWITCH_1
S4 VEE ESDn VEE ESDn S_VSWITCH_1
S3 ESDp VCC ESDp VCC S_VSWITCH_1
S5 VEE ESDp VEE ESDp S_VSWITCH_1
.MODEL S_VSWITCH_1 VSWITCH (RON=50 ROFF=1e12 VON=500e-3 VOFF=450e-3)
.ENDS
.SUBCKT PSRR_CMRR_0_OPA1641 psrr_in psrr_vccb mid
.model R_NOISELESS RES ( TCE=0 T_ABS=-273.15)
R74 mid psrr_in R_NOISELESS 1
G_2 psrr_in mid 4 mid -36.1316
R2b mid 4 R_NOISELESS 2846443.8473
C2a 4 5 1.0178e-14
R73 5 4 R_NOISELESS 100MEG
R49 mid 5 R_NOISELESS 1
GVCCS7 5 mid 6 mid -1
R2a mid 6 R_NOISELESS 11367.1456
C1a 6 7 2.2769e-12
R48 7 6 R_NOISELESS 100MEG
G_1 7 mid psrr_vccb mid -0.0021692
Rsrc mid 7 R_NOISELESS 1
.ENDS
.SUBCKT PSRR_CMRR_1_OPA1641 psrr_in psrr_vccb psrr_mid
R80 psrr_mid psrr_in R_NOISELESS 33.3333
C27 psrr_in 4 1.5915e-09
R79 4 psrr_in R_NOISELESS 100MEG
GVCCS8 4 psrr_mid psrr_vccb psrr_mid -0.13345
R78 psrr_mid 4 R_NOISELESS 1
.ENDS
.SUBCKT PSRR_CMRR_2_OPA1641 psrr_in psrr_vccb psrr_mid
R80 psrr_mid psrr_in R_NOISELESS 45.5638
C27 psrr_in 4 1.5877e-09
GVCCS8 4 psrr_mid psrr_vccb psrr_mid -0.30495
.ENDS
.SUBCKT VCCS_LIM_2_0_OPA1641 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 0.021535
.PARAM IPOS = 0.6168
.PARAM INEG = -0.6168
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)}
.ENDS
.SUBCKT VCCS_LIM_1_0_OPA1641 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-4
.PARAM IPOS = .5
.PARAM INEG = -.5
.ENDS
.SUBCKT AOL_ZO_0_OPA1641 AOL_INP AOL_INN CLAMP VSENSE CLAW_CLAMP CL_CLAMP ZO_CLEFT ZO_CRIGHT ZO_OUT MID
.MODEL R_NOISELESS RES ( TCE=0 T_ABS=-273.15)
C1_A0 CLAMP MID 3.034e-08
R4_A0 MID CLAMP R_NOISELESS 1MEG
XVCCS_LIM_2_A0 4_A0 MID MID CLAMP VCCS_LIM_2_0_OPA1641
R3_A0 MID 4_A0 R_NOISELESS 1MEG
XVCCS_LIM_1_A0 AOL_INP AOL_INN MID 4_A0 VCCS_LIM_1_0_OPA1641
R4_VS VSENSE MID R_NOISELESS 1K
GVCCS4_VS VSENSE MID CLAMP MID -1M
C2_A2 out2 MID 6.6315e-14
R3_A2 out2 MID R_NOISELESS 1MEG
GVCCS3_A2 out2 MID VSENSE MID -1U
C3_A3 4_A3 out3 4.9379e-12
GVCCS4_A3 4_A3 MID out2 MID -639.8821
R4_A3 4_A3 MID R_NOISELESS 1
R5_A3 out3 4_A3 R_NOISELESS 10K
R6_A3 out3 MID R_NOISELESS 15.6523
C2_A4 out4 MID 1.0015e-15
R3_A4 out4 MID R_NOISELESS 1MEG
GVCCS3_A4 out4 MID out3 MID -1U
C2_A5 out5 MID 8.1759e-16
R3_A5 out5 MID R_NOISELESS 1MEG
GVCCS3_A5 out5 MID out4 MID -1U
C2_A6 out6 MID 8.1759e-16
R3_A6 out6 MID R_NOISELESS 1MEG
GVCCS3_A6 out6 MID out5 MID -1U
C2_A7 out7 MID 8.1759e-16
R3_A7 out7 MID R_NOISELESS 1MEG
GVCCS3_A7 out7 MID out6 MID -1U
C2_A8 out8 MID 2.8937e-16
R3_A8 out8 MID R_NOISELESS 1MEG
GVCCS3_A8 out8 MID out7 MID -1U
R4_CC CLAW_CLAMP MID R_NOISELESS 1K
GVCCS4_CC CLAW_CLAMP MID out8 MID -1M
R4_CL CL_CLAMP MID R_NOISELESS 1K
GVCCS4_CL CL_CLAMP MID CLAW_CLAMP MID -1M
G_Aol_Zo Zo_Cleft MID CL_CLAMP ZO_OUT -89.0517
GVCCS1_1 outz1 MID Zo_Cright MID -83.6706
C1_1 Zo_Cleft Zo_Cright 9.5519e-06
R2_1 Zo_Cright MID R_NOISELESS 120.9619
R1_1 Zo_Cright Zo_Cleft R_NOISELESS 10K
Rdc_1 Zo_Cleft MID R_NOISELESS 1
GVCCS2_2 outz2 MID net2 MID -1
C2_2 5_2 MID 3.9653e-12
R5_2 net2 5_2 R_NOISELESS 10K
R4_2 net2 outz1 R_NOISELESS 165044.5518
R7_2 outz1 MID R_NOISELESS 1
R1_3 2_3 MID R_NOISELESS 1
R11_3 5_3 MID R_NOISELESS 6.7534
C4_3 5_3 outz2 1.6422e-13
R10_3 5_3 outz2 R_NOISELESS 10K
XVCVS_LIM_1 5_3 MID MID 2_3 VCCS_LIM_ZO_0_OPA1641
R9_3 outz2 MID R_NOISELESS 1
Rdummy MID ZO_OUT R_NOISELESS 1584.893
Rx ZO_OUT 2_3 R_NOISELESS 15848.93
.ENDS
.SUBCKT VCCS_LIM_ZO_0_OPA1641 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1481.7407
.PARAM IPOS = 1160.123E3
.PARAM INEG = -918.604E3
.ENDS
.SUBCKT FEMT_0_OPA1641 1 2
.PARAM NVRF=0.8
.PARAM RNVF={1.184*PWR(NVRF,2)}
E1 3 0 5 0 10
R1 5 0 {RNVF}
R2 5 0 {RNVF}
G1 1 2 3 0 1E-6
.ENDS
.SUBCKT VNSE_0_OPA1641 1 2
.PARAM FLW=0.1
.PARAM NLF=46.4919
.PARAM NVR=5.0539
.PARAM GLF={PWR(FLW,0.25)*NLF/1164}
.PARAM RNV={1.184*PWR(NVR,2)}
.MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVN
D2 8 0 DVN
E1 3 6 7 8 {GLF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNV}
R5 5 0 {RNV}
R6 3 4 1E9
R7 4 0 1E9
E3 1 2 3 4 1
.ENDS
.SUBCKT VCCS_LIMIT_IQ_0_OPA1641 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-3
G1 IOUT- IOUT+ VALUE={IF( (V(VC+,VC-)<=0),0,GAIN*V(VC+,VC-) )}
.ENDS
.SUBCKT CLAMP_AMP_LO_0_OPA1641 VC+ VC- VIN COM VO+ VO-
.PARAM G=1
GVO+ COM VO+ VALUE = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)}
GVO- COM VO- VALUE = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)}
.ENDS
.SUBCKT CLAMP_AMP_HI_0_OPA1641 VC+ VC- VIN COM VO+ VO-
.PARAM G=10
.ENDS
.SUBCKT VCCS_LIM_GR_0_OPA1641 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 1.2336E1
.PARAM INEG = -1.2336E1
.ENDS
.SUBCKT VCCS_LIM_4_0_OPA1641 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 0.2352E1
.PARAM INEG = -0.231E1
.ENDS
.SUBCKT VCCS_LIM_CLAW+_0_OPA1641 VC+ VC- IOUT+ IOUT-
G1 IOUT+ IOUT- TABLE {(V(VC+,VC-))} =
+(0, 2.1186E-4)
+(12.1998, 0.0003505)
+(24.3996, 0.00037005)
+(32.5328, 0.00049199)
+(32.9395, 0.00050932)
+(33.7528, 0.00055193)
+(34.5661, 0.0006607)
+(35.3794, 0.00086684)
+(36.1927, 0.0014151)
+(36.5994, 0.0018692)
.ENDS
.SUBCKT VCCS_LIM_CLAW-_0_OPA1641 VC+ VC- IOUT+ IOUT-
+(0, 2.1186E-4)
+(9.66, 0.00036002)
+(19.3199, 0.00036763)
+(25.7599, 0.00037452)
+(26.0819, 0.00037487)
+(26.7259, 0.00037556)
+(27.3699, 0.00037625)
+(28.0139, 0.00037694)
+(28.6579, 0.00072576)
+(28.9799, 0.0018986)
.ENDS
.SUBCKT VCCS_LIM_3_0_OPA1641 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 0.1176E1
.PARAM INEG = -0.1155E1
.ENDS
.SUBCKT OL_SENSE_0_OPA1641 COM SW+ OLN OLP
GSW+ COM SW+ VALUE = {IF((V(OLN,COM)>10E-3 | V(OLP,COM)>10E-3),1,0)}
.ENDS
.SUBCKT VCCS_EXT_LIM_0_OPA1641 VIN+ VIN- IOUT- IOUT+ VP+ VP-
.PARAM GAIN = 1
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VIN+,VIN-),V(VP-,VIN-), V(VP+,VIN-))}
.ENDS
holger.vogt
The OpAmp may be vey well simulated in ngspice, but...
You will need a recent ngspice version.
You have to enable PSPICE compatibility.
I have just checked what ngspice version is distributed with the (free downloadable) Eagle 9.6.2. It is ngspice-26, stemming from Jan. 2014. This is far too old, it does not have the PSPICE compatibility mode. Current version is ngspice-33 from October 2020.
PSPICE compatibility is useful, when simulating PCBs with OpAmps and other discrete circuits. Very often the semiconductor vendors supply PSPICE-compatible SPICE simulation models. On the other hand ngspice should also accept HSPICE simulation models (typical for IC work), which are mutually exclusive to PSPICE. So one has to decide and set a switch (in modern ngspice).
So please urge the Autodesk/EAGLE maintainers to provide a ngspice update.
If you are on MS Windows, I could provide some hints here how to upgrade. With Linux or macOS this may not be so straightforward, but still be possible as well.
Please let me know if you are interested.
Holger (ngspice maintainer)
Dear Holger,
thank you very much for your reply.
Indeed, it would be very useful if one could simulate in EAGLE with original PSPICE data of opamp manufacturers.
An upgrade from 2014 version to an up to date 2020 version would make EAGLE more compatible
@Admin: could you maybe forward the proposal to include ngspice 33 in the next release of EAGLE?
Yes, I would be happy , if in the meantime you could point to the way of linking ngspice 33 to EAGLE (Win10)
Thank you very much
Frank
PS: When having several jumpers, headers, plugs in the circuit, their electrical models are missing and thus a simulation is only possible after deleting these elements (or after attributing each of them an electrical model) . Is there a smart solution?
holger.vogt
I did some tests and found incompatibilites between ngspice-33 and the old ngspice-26, concerning the interface to EAGLE. It may take a few days to come up with an intermediate solution.
