Schematic Traces Missing
rlnou812
rlnou812
Community Visitor
Community Visitor
I made a schematic back in 2018, not sure what version of Eagle I used then but that computer is gone.
I found the RPi file made in 2018 but when I open it with the latest version 9.6.2, most of the traces are missing that link the components.  I hate to reverse engineer this project if there is a solution.
jorge_garcia
Hi @rlnou812,
I hope you're doing well. Are you saying that you only have the schematic? Basically, unless you have both the schematic and the board the design is incomplete. In the case where you only have the schematic then you'll need to redo the layout.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
rlnou812
Community Visitor
Community Visitor
The folder includes files #1 through #6, the .sch file and eagle.epf file. Also untitled.s## file.
I just thought it was a non compatibility issue between Eagle versions.
