Schematic Editor Freeze after move
j
Message 1 of 27
j
Schematic Editor Freeze for about 2 seconds after every move (e.g. move component or net).
Replies (26)
Message 21 of 27
Please provide an ETA for this fix? Its becoming increasingly difficult to use Eagle. The v9.1.3 crashes at least once per hour on Windows on sizeable projects so it is not an option for me.
Message 22 of 27
In EAGLE 9.2.2 the same bug. And in paste group command too. Only one solution for complex projects is lot of sheets with small amount components.  Carefully test a version before release!
Message 23 of 27
jorge_garcia
Hi Guys,
I hope you're all doing well. This fix will be released in early January. We know it's causing a lot of grief.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 24 of 27
Any update for this bug?
I just started running into this problem myself and it's very frustrating.
I'm running Win10 pro, Eagle 9.2.2, and PC is an i7 with 16GB ram and SSD.
Message 25 of 27
edpataky
Eagle version 9.3 has the fix and is going through the release process now .. look for an update in the next day or so
Message 26 of 27
edpataky
the fix for this has been released and there is a new version available fyi
Message 27 of 27
kd6oji
Ed and the Eagle Team,
Thank you for your attention to these issues. I've installed 9.3 and so far no misbehavior has been noted as to the freezing issue. Also, the 3d video card workaround we've had to use (gpu_blacklist) seems to have been resolved also, as I can now directly modify and edit in the 3d library tool without having to execute the command to override by a launcher batch file.
Nice work guys, and now to explore the newer features you've included!
