"Error pulling from Fusion"
davidHMVUB
Message 1 of 12
davidHMVUB
I am getting the unhelpful error "Error pulling from Fusion" when trying to pull from Fusion.
I suspect that it is because I moved the PCB in the Fusion timeline. Restarting Fusion and Eagle didn't solve the problem.
I had originally moved some components in Fusion to match positions in the Fusion model. I decided to abandon those changes and see if pushing from Eagle would reset things. Interestingly, it appears to have moved the PCB back to its original position in the timeline. I then moved the components again in Fusion, but once again received "Error pulling from Fusion" when trying to pull.
Any ideas?
Replies (11)
Message 2 of 12
jorge_garcia
Hi @davidHMVUB,
I hope you're doing well. At this point the model is probably messed up. If possible I would suggest breaking the link between EAGLE and fusion and then do a new push to Fusion360.
I'll ping out developers on this to see if they have any other ideas.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 12
yqliu
Hi @davidHMVUB,
Did you see any more text after "Error pulling from Fusion" in the message dialog? Can you copy the full message or the screenshot here?
Richard
Message 4 of 12
orbssam
Hello! I am getting exactly the same error when making a simple fillet change in a board profile,I have been using the bridge Eagle~Fusion for a while now and never experienced this as well doing much more complex changes.I have tried everything, multiple times resetting the link, pull, push etc etc. I am wondering/hoping there has been a solution perhaps? The error in this context is extremely unhelpful I agree 🙂
Message 5 of 12
orbssam
Hello again, in more detail. The message box simply reads Error Pulling from Fusion, see attached image. I have now spent enough time trying what I can to debug the issue that I can say it makes no sense, is there an option to just sync the profiles? Perhaps it is a custom part that is causing an issue, but then again, I have no idea. Annoyingly, my design has 4 pcbs which are totally fine pulling from fusion, this is the odd one out and I can't think why. If there would be any support available, I would be most grateful. Screenshot 2019-03-15 at 11.25.25.png
Message 6 of 12
yqliu
Hi @orbssam ,
can you go to Fusion and check if there is any issue with the PCB feature. If the timeline marker is rolled back to some position before the PCB feature, pull operation will fail.
Message 7 of 12
orbssam
Hi, no it all looks fine. Screenshot attached.
Message 8 of 12
orbssam
Honestly, I tried everything. Support would be helpful, but have since decided not to use this feature for this board. I want to use it in the future so am looking forward to some more descriptive error messages when you finish the project! It's great otherwise! 🙂
Message 9 of 12
jalilmB2AY9
I am facing the exact same issue, I basically created a new design to see if the issue was related to timeline but I still get the same error with absolutely no reference to why it failed.
The only thing that stands out for me is I recently updated to eagle 9.3.2 and this is my first design on the newer version of eagle.
Message 10 of 12
yqliu
We just found an issue with Fusion Team Hub. How many hubs do you have? If you have multiple hubs, can you try a different one?
Message 11 of 12
orbssam
Just one hub I have.
Message 12 of 12
jalilmB2AY9
I am not using Fusion Team functionality at all, Its just me working on a single design.
I have the existing error pulling from Fusion and now i see a new error while trying to push a new design. I have attached a picture with the post. Is there a dump log created by EAGLE ? It might be worth looking to troubleshoot the problem.
