@edwin.robledo wrote:
The default cam processor templates do not include Layer 20, this can be manually added. Select the profile section of the CAM Job and include layer 20.
@edwin.robledo I think I know what's going on here based on your above statement. The new CAM processor is relying on the detect board shape feature to be enabled in order to be able to add the board shape to the profile without specifically using the Dimension layer. If you turn that feature off and go to the profile setup in the default CAM job, even with "Board Shape" ticked there is no shape showing. I think the CAM processor needs to check that this feature is enabled and if not then grey out that option and include the Dimension layer instead.
@Anonymous You can turn that setting back on in Options->User Interface up in the top "Layout" section:
@edwin.robledo I think this location for that setting is very misleading. It implies it only affects the UI and specifically the layout of the UI but it does not, it's not UI related, it's design related and should really be somewhere completely different with options which affect the design. I'd actually suggest it be in the DRC setup with all the other options which are design affecting.
Best Regards,
Rachael
