Place components on a circumference
CarloTentelli9165
CarloTentelli9165
I've a lot of leds to placment on a circle (about 50). There's an automatic disposition?
In attached an example(14 leds).
PS I will wish to use maximun precision(0.01). At times the space is very very small
Best regards.
rachaelATWH4
You can use the command line and polar coordinates to place your LED's in a circle without too much effort.
First of all you want to set a mark point at the centre of where the circle will be.
MARK (x y);
Then you move your LED's first to the mark and then to their correct location as follows:
MOVE LED1 (R 0 0); MOVE LED1 (P radiusVal angle);
Where radiusVal is the radius of the circle (clearly!) and angle is incremented for each LED in the circle.
So lets say I want to place 12 LED's, LED1 through LED12 in a 30mm radius centred at 50mm x 75mm on the board. 360/12 = 30.
GRID MM; MARK (50 75);
MOVE LED1  (R 0 0); MOVE LED1  (P 30 0);
MOVE LED2  (R 0 0); MOVE LED2  (P 30 30);
MOVE LED3  (R 0 0); MOVE LED3  (P 30 60);
MOVE LED4  (R 0 0); MOVE LED4  (P 30 90);
MOVE LED5  (R 0 0); MOVE LED5  (P 30 120);
MOVE LED6  (R 0 0); MOVE LED6  (P 30 150);
MOVE LED7  (R 0 0); MOVE LED7  (P 30 180);
MOVE LED8  (R 0 0); MOVE LED8  (P 30 210);
MOVE LED9  (R 0 0); MOVE LED9  (P 30 240);
MOVE LED10 (R 0 0); MOVE LED10 (P 30 270);
MOVE LED11 (R 0 0); MOVE LED11 (P 30 300);
MOVE LED12 (R 0 0); MOVE LED12 (P 30 330);
Best Regards,
Rachael
C.Nicks
There is also a ulp that automates what Rachael posted. The ulp is called component-array.ulp, written by Jorge. It works for placing rectangular and circular arrays.
component-array.ulpcomponent-array.ulpAfter running circularAfter running circular
Best Regards,
Cameron
Eagle Library Resources
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
rachaelATWH4
Oh very cool! I didn't know about that one. I was just about to write something similar to automate it Smiley Happy
I was thinking it would be good to able to use the components in a group as the basis for the array placement or specify them with a string such as LED1-4,LED11-14,LED21-24 and internally it work out what that means so you don't have to type every single one in. Maybe I could add something like this to my moveTools.ulp?
Best Regards,
Rachael
