Off-Sheet Connections
Hi, I'm moving to eagle cadsoft from other altium. Does any one know how can create connectors between multiple sheets ? Also, would you know a ulp script that can help in navigating through different connectors ? (I've used https://raw.githubusercontent.com/loneFunction/Library/master/ULP/GLOBAL/MLutils.ulp, but its giving a issue saying "no net selected").
Gurman
rachaelATWH4
If you add a label to a net and make sure it is set to type XREF it'll so off-page style symbols on the ends of your nets and add cross references to the labels shown.
I'm not quite sure what you mean here? If you could expand on what you are trying to achieve here that would help.
Best Regards,
Rachael
That ulp script helps in navigating to nets that are off different sheet. So once everything is working fine with that ulp, I'll be able to navigate to different nets from say sheet x to sheet y. Please see this gif. https://gph.is/2RKKufh
Gurman
