Managed Libraries - Eagle Library corrupted after pushing from Fusion 360
LaCocoRoco
Message 1 of 22
LaCocoRoco
Hi, since yesterday i have a problem with my managed library.
Something must went wrong while i pushed an design update from Fusion 360.
As i refreshed my managed library in Eagle to the latest version, i got <polygonshape> errors.
When i delete the <polygonshape> as example from line 672 to line 688,
the failure for this line is solved until i merge or push the managed librarie.
I reinstalled Eagle.
I removed the Document Folder
I removed AppData Eagle Folder.
I made a backup of my managed library before this problem started (I work on several Workstations).
When i "Update all assets to the lates version" my backup library also gets corrupted.
I still can work with the library itself, but always when i open it in eagle i get a ".rpt".
I invested many hourse in this project, so i hope i there is a way to fix this.
Account: [email protected]
Because i could't upload the ".rpt" i added the format ".txt" at the end.
Because i could't upload the ".lbr" i zipped it.
Replies (21)
Message 21 of 22
LaCocoRoco
Hi @HelenChen-AutodeskQA , the problem is fixed. Thank you very mutch for the Help.
There are still some problems i can not fix, but they are negligible.
As example, it is still not possible to delete the old corrupted libraries.
If i delete them they do not disapear.
There is also no possibility to delete Silkscreen, Pad or Text Sketches.
I once exported this Model from a Library Package.
I also can not realy modify the 3D Preview in Eagle.
If as example i try to hide the Sketch in Fusion, it still apears in the Eagle 3D Model Preview.
These problems are not "game breaking" but still are a "bummer" 😄
Yours Andreas
Message 22 of 22
LaCocoRoco
I think i will close this Topic.
The main problem is fixed and the rest is insignificant.
