Library for reed relay
I finished up a new library for a specific reed relay 117SIP.
I also made a public git for it if anyone is interested in downloading it.
This relay is very compact, and works with 5VDC.
GitHub link
I've also added some other libraries:
-Nema connector: this are basically the holes of the 7 pin nema connector, usually used in street lighting.
-Tact Switch (2 terminals): this is for a simple tact switch with two terminals. I prefer this to the common 4 terminals tact switch, because its actually the same thing but you cant get it wrong when you solder it.
-Terminal1x2 (5.08mm): it's one of thos green terminals with the screws. I kinda got tired of searching for one and made it. (same for everyone).
