Eagle Bug report
Eagle Bug report
Eagle Bug report
Hello!
I couldn't find a bugreport site for autodesk eagle, so my actual question is: Do you have a website to report bugs? If so It would be nice if you can post the link for me. Now to get to the bugs im experiencing...
Eagle has made some good progress since Autodesk overtook it, but I'm also getting about two random crashes per Workday since the first Autodesk Eagle version. It's pretty hard to tell when those crashes happen, mostly when Eagle is reading or writing board or schematic files, like saving or opening an existing brd/sch file but also out of nowhere when moving the board-view for example. The crashes persists on Eagle 9.1.0.
The reason to post now, is the performance issue while rendering boards with Eagle 9.1.0. It is pretty awful on my machine now (i7 4770k, GTX Titan). It is lagging behind, tearing and has about 2-3 FPS. This renders the layout editor pretty much useless for me. The problem was not present in Eagle 9.0.1.
Sidenotes:
Eagle version: Eagle 9.1.0 Premium, Windows, 64Bit
Hardware: i7 4770K @ 4.1GHz; GTX Titan 6GB; 16GB DDR3-RAM
Tested on my Windows10 working machine and a clean installed Windows10
jorge_garcia
Hi @Anonymous,
I hope you're doing well. I'm going to be contacting you privately to get some additional information about this problem. Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
