Large Cursor Ghosting in Eagle 9.1
jpeterse77
Message 1 of 12
jpeterse77
I just installed Eagle 9.1, running on Linux Mint 18.3, using Intel Sky Lake Integrated Graphics, with a HIDPI display (2880x1620 resolution).
My issue is, that the default cursor in board layout is far to small. It disappear against the board I'm working on.
So I turned on the large cursor, but with that, I get ghosting of the cursor when I move the mouse.
The ghost lines disappear when I update the display by panning or zooming, but it's quite annoying.
Any idea on how I can better control the cursor size?
is there a QtWebEngine parameter I can set?
Replies (11)
Message 2 of 12
jorge_garcia
Hi @jpeterse77,
I hope you're doing well. Go to Options > Set. Make sure that use Alpha blending is checked. Having that option unchecked currently leads to ghosting.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 12
jpeterse77
Thank you for the prompt response.
I think I have that checked already.
ghosting cursor in Eagle 9.1.pngBTW: I really like the changes you are making to Eagle. Kudos for taking on the task of overhauling the interface.
Message 4 of 12
jorge_garcia
Hi @jpeterse77,
Go into the EAGLE installation folder and look at the readme, try the first suggestion.
export LIBGL_ALWAYS_SOFTWARE=1
./eagle
This will force software rendering, let's see if the ghosting goes away.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 5 of 12
jpeterse77
I tried starting Eagle with:
export QT_AUTO_SCREEN_SCALE_FACTOR=0 && export LIBGL_ALWAYS_SOFTWARE=1 && /opt/eagle/eagle-9.1.0/eagle &
Still get the same ghosting.
I also downloaded 9.1.1, and I have the same issue with the most recent version.
Message 6 of 12
jorge_garcia
Hi @jpeterse77,
I've pinged the developers to see what might be going on here. One thing I can suggest is to see if there are any other graphics drivers available for your computer. I run the same version of Mint that you do but I have an NVIDIA graphics card.
Best Regards,
Jorge Garcia
Message 7 of 12
jpeterse77
Thank you Jorge.
I only have the build in graphics adapter.
00:02.0 VGA compatible controller: Intel Corporation Sky Lake Integrated Graphics (rev 0a) (prog-if 00 [VGA controller])
        DeviceName:  Onboard IGD
        Subsystem: Dell Skylake Integrated Graphics
        Flags: bus master, fast devsel, latency 0, IRQ 126
        Memory at db000000 (64-bit, non-prefetchable) [size=16M]
        Memory at 90000000 (64-bit, prefetchable) [size=256M]
        I/O ports at f000 [size=64]
        [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
        Capabilities: [40] Vendor Specific Information: Len=0c <?>
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [d0] Power Management version 2
        Capabilities: [100] #1b
        Capabilities: [200] Address Translation Service (ATS)
        Capabilities: [300] #13
        Kernel driver in use: i915
        Kernel modules: i915
# modinfo i915 -F vermagic
4.15.0-24-generic SMP mod_unload
Message 8 of 12
jpeterse77
Updated to 9.1.2 - issue persists
Large cursor continue to leave a leave a ghost trail when moving the cursor.
And the small (normal) cursor is drawn with so narrow lines, that it completely disappear when moving over components and traces.
Message 9 of 12
jorge_garcia
Hi @jpeterse77,
I hope you're doing well. With the release of 9.1.2 there are now some HDPI settings that you can control and adjust. In the control panel go to Options > User Interface you'll see them on the middle left. Try different combinations of these. Do any of these combinations resolve the issue?
Please let me know if you continue to run into problems
Best Regards,
Jorge Garcia
Message 10 of 12
jpeterse77
I tried all combinations of the new options in the option dialog.
But none of the combinations resolve the issue.
Message 11 of 12
jorge_garcia
Hi @jpeterse77,
I hope you're doing well. Let's try this go into
~/.local/share/Eagle/
Go into the settings folder and rename the eaglerc file to eaglerc_bak or something like that. Make sure EAGLE is closed when you do this. Then start EAGLE and try the large cursor. If the ghosting goes away I'm going to need the eaglerc_bak file to for review.
Best Regards,
Jorge Garcia
Message 12 of 12
jpeterse77
Hi Jorge,
Renaming the eaglerc file did not resolve the issue.
So it doesn't appear to be an issue with the configuration file.
I'm on a Dell XPS 13 (model 586WPF2) the version with high resolution QHD+ infinity edge display, driven by integrated Intel Iris graphics 540 processor.
Here's some information on the graphics drivers:
glxinfo | grep -i opengl
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) Iris Graphics 540 (Skylake GT3e)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 18.0.5
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 18.0.5
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 18.0.5
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
