How to revert highlight color option back to black?
I just updated from v8.3.2 to v8.7.0 and am having an awful time with the new color pallet - as as usual I can't fathom why the default would ever be changed. Typically I avoid installing new versions of Eagle because literally every update brings in more bugs to things that were previously broken - and I have to juggle a few versions to work around problems so I don't know where the issue was introduced but this small annoyance is making it impossible for me to work well.
In every older version of eagle if you right-click an object in either schematic or board the outline and text, value, and tplace become highlighted in black (when using white background). Normally they are grey by default and become black when you right-click, or when you use the show command, or when you move them. Now in v8.7.0 when you show, select, or move an object they become LIGHTER! Its a problem with overlapping text that hasn't been formatted yet which is my last step, or when parts in the board are outside the dimensions and have a grey background it's just difficult to see.
I cannot for the life of me get this to change back. I've tried changing the highlight color in the pallet to black (255, 255, 255, 255 alpha), turning alpha channel blend one and off, and changed the new "highlight %" option to 50%, 0%, and 100% and no combination of these results in BLACK. The best I could accomplish is a little darker grey but not black. I achieve this by setting the highlight color (pallet row 2, column 8) to BLACK (255, 255, 255, 255), unchecking "use alpha blending" and setting the highlight option to 0% and now it goes from a middle grey to a darker grey when I right-click but DOES NOT CHANGE at all when I go to move the object - in fact all it does is show me dots where the lines used to draw the text overlap.
It is frustrating that there is no explanation of how the pallet works I've looked in the guide and searched the forum and google and all there is is a few sentances that say the first row is primary the second row is highlighted and then also there are other rows. How is there no labels? Why was this changed? Why does it get LIGHTER by default when you click something? And why can't I change it back? Why is every "improvement" always a step backwards?
