GROUP select in FUSION360 sometimes not works at first try.
HarrySatt
Message 1 of 9
HarrySatt
Hi
GROUP select in FUSION360 sometimes not works at first try. I see a behaviour I am not used to from earlier days in EAGLE. Now in FUSION360 electronics schematic editor sometimes or better most of trying to use the GROUP command, either normal or polygon I see that the grouping did not work and I need to use the GROUP command a second or theird time until it captures the group. I that known? Can I do something to get rid of this?
Regards, harald
@jorge_garcia
@RichardHammerl
Replies (8)
Message 2 of 9
jorge_garcia
Hi @HarrySatt ,
Could you record a screencast showing this behavior as far as I know there's no such issue. One thing to keep in mind, whenever you form the group, in order for the select to work, you must click on a member of the group. You can't click just in empty space.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 9
HarrySatt
I mean the rectangle I draw to form the group. sometimes the contents (inside the rectangle ) is not activated, Not highlightend. If I use polygone grouping the highlight is shortly shown but sometimes vanishes immediatly.
But that behaviour is really seldom, so screenrecording is nearly impossible.
I think you keep this in mind and I forget it for the first.
thank you for fast response.
Regards, Harald
Message 4 of 9
ugLB8P8
Observer
Observer
I can reproduce this behaviour to 100% with the following sequence in the schematic editor.
First I use the "move" command to move for example a resistor by using left click. After moving the resistor to a new location, I left click again to locate it at the position.
Then I use "Select" "Group with polygon" from the menu.
After drawing the selection poygone arround some items using left clicks, I use right click to close the polygone.
Voila, the group selection is empty.
When I try the same selection starting with "Select" "Group with polygon"  again. The group selection succeedes.
I can see a similar behaviour also in the board editor.
Because I use this selection very frequently, it is disturbing the workflow a lot.
Message 5 of 9
HarrySatt
Definitely the issue I mean. The same I also encounter with standard GROUP command. Makes the workflow a bit crumpy. Sometimes you see that the command does not catch the objects inside the polygon or rectangle.
@jorge_garcia
@RichardHammerl
Message 6 of 9
jorge_garcia
Hi @HarrySatt ,
I hope you're doing well. I'll keep an eye out and see if we can get it reproduce consistently.
Best Regards,
Jorge Garcia
Message 7 of 9
panpan_fan
Hi @HarrySatt  @ugLB8P8
Thanks for reporting this issue!
I can reproduce this issue withe steps you mentioned.
I have reported a ticket to our develop team and will keep you updated when I get more information.
Panpan Fan
Message 8 of 9
panpan_fan
For this issue, you can try to Press ESC after Move, then do Group Select.
Before the fix for this issue, you can use the workaround.
Please have a try, thanks!
Panpan Fan
Message 9 of 9
panpan_fan
I hope you are doing well!
Today we release Fusion 360 V2.0.10244 and the group issue should be fixed in it.
Panpan Fan
