Gerber generation serious error
mario.brizida
mario.brizida
After upgrading to Eagle ver. 9.1, I needed to genertate gerbers to produce a pcb, and got incoorect vcut files.
Please pay attention to this error. Last veersion worked fine with same source file.
Please correct issue urgently. In annex I send you wrong gerbers, Eagle original file and CAM configuration file.
If there's a problem with my source or CAM files, please advise and accept my sorries.
Thank you.
jorge_garcia
Hi @mario.brizida,
The fix for this issue will be out in our next release. Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
mario.brizida
Hi Jorge Garcia;
Thanks for your quick reply.
Hope you don't take too much time to correct error. Only solution I have right now to generate gerbers is to use version 9.01, that gives some errors because al drawing was generated in last version. It's a fact that in  last times Eage won high quality, and I'm very satisfied with it. Congratulations to all team. But is also a fact that bugs related to gerber generation are very serious and could drive to catastrophic results and high losses. Please take care.
jorge_garcia
Hi @mario.brizida,
I hope you're doing well. Our next release will have this solved.
Best Regards,
Jorge Garcia
