Custom layer automatic mirror
mateusz.lower
mateusz.lower
I create a new layer in the library and I have a question whether in Eagle it is possible for the custom layer to behave like e.g. tDocu and bDocu layers,I creating tAss_docu and bAss_docu layers, i.e. in the component I define a custom top layer(tAss_docu) and after turning the component in the design it automatically remains it turned into a bottom layer(bAss_docu)
I need this! I would be happy with a solution based on a naming convention (swapping all of the tSomething into bSomething and vice versa).
Reasoning: I'm using a custom layer for PCB silkscreen documentation which I want only on the silkscreen (tPlace + tCustom), and not on the printed documentation (tPlace + tDocu).
jorge_garcia
Hi @Anonymous ,
I hope you're doing well. This is possible, the key is that you have to use specific pairs of layers. Built-in there are 4 pairs of layers available to users that automatically mirror each other. These are the 4 pairs
53/54, 55/56, 57/58 and 59/60.
Those are the only pairs of layers that have this property.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Hi Jorge,
thank you very much for this info, it solves my needs.
However, I had to add/activate the layers in the LBR file with a text editor. It's unfortunate that the existence of these layers is so well hidden...
Tomas
