Correct method to define parts without 3D-package
Andreas.Schimke
Message 1 of 17
Andreas.Schimke
Hello all,
what is the correct way to define parts with "no 3D-package", like pcb marks, test points and so one?
In a other thread was the suggestion given to hide the not needed components in Fusion.
But, hiding a few (20-100 components) in Fusion isn't fun at all, especially if you redoing this by placing your pcb in a new Fusion model...
Also in the sync menu will show you everytime the notice "!" that no 3D model is defined.
Therefore my question what is the intend way we as user should define our parts in Eagle, so that push to fusion show no alert and no package is visible in Fusion?
Andreas
Replies (16)
Message 2 of 17
jorge_garcia
Hello Andreas,
Welcome to our forum! Our devs are going to implement a way to tell Fusion that a specific component doesn't need a 3D model. For now the way some users are working around it is by uploading an empty step file. It's a hack but for now it's probably the best way around this issue until we have a more permanent solution.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 17
Hello -
Curious to see if there has been any update to this request, as we are facing the same issue (we have a moderate number of items such as conditionally installed components, surface test points, JTAG header pads etc.) that do not have physical models associated with them. I tried the trick of uploading an empty step file, but when I export a step file from an empty file in Fusion 360, and then try to upload this step file as a model when editing a component's package in the managed library at circuits.io, this results in an error message of "Failed to convert model file". So at the moment I can't figure out a method to get rid of the default box models other than hiding them after the translation from Eagle to Fusion 360.
Darrin
Message 4 of 17
jorge_garcia
Hello Darrin,
I hope you're doing well. For now the solution you are using , is the best we have at the moment but we are going to improve this.
Best Regards,
Jorge Garcia
Message 5 of 17
Thanks Jorge.  Unfortunately, it does not appear that the library.io component editor allows the upload of an empty step file (or at least an empty step file created by Fusion 360).  Do you have any suggestions that could get around this?
Darrin
Message 6 of 17
eric.n.tech
+1 to this issue. When uploading a completely blank step file, it fails. I have had to make a super tiny fake file that is unnoticeable and upload that. It is quite frustrating, hope this gets fixed soon.
Message 7 of 17
jorge_garcia
Hi Guys,
Just an update, there is one other option for this. When you go to assign a 3D model, you have a grey cube which is the default representation of the component. If you don't want to assign a 3D model, set the X, Y, and Z dimensions to be zero and save that.
You may find that option easier than trying to make a really small step file or and empty one.
Best Regards,
Jorge Garcia
Message 8 of 17
rnunez4AQMR
Interesting.  I'll try that.  If it works, it will at least eliminate the need to manually hide all the boxes that come over to Fusion 360, but I'm not sure if the warnings would still show when pushed from Eagle?
Message 9 of 17
jorge_garcia
Hi @rnunez4AQMR,
Unfortunately, the warnings will still show if memory serves. We are still working to make this better.
Best Regards,
Jorge Garcia
Message 10 of 17
pyroballpcs
Hello I'm wondering if this has had any progress?
Is the best method to still generate a model with 0x0x0 dimensions?
Message 11 of 17
Any progress on this?
Message 12 of 17
flZLV3C
any progress please?
Message 13 of 17
jorge_garcia
Hello everyone,
Unfortunately, no news on this front. The best option is still to do the 0x0x0 dimensions thing.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 14 of 17
Hello, Now the 0x0x0 dimension thing does not work. Would you have a way to not have the black box show up?
Thank you
Message 15 of 17
0507787R
Observer
Observer
@jorge_garcia how is this still an issue more than 2 years after being reported??? Surely this cannot be a complicated matter we just want to have no model for a part? as mentioned previously there is currently as of today NO working workaround, I have tried 0x0x0 and empty step, but still get a black box on my Fusion model.
Message 16 of 17
jorge_garcia
Hi @0507787R ,
Thanks for the bump. There's an improvement coming to Fusion 360 Electronics for this soon, but it will not be backported to EAGLE. For now the best option, is to hide the blackbox on your Fusion 360 model.
Best Regards,
Jorge Garcia
Message 17 of 17
khagenLFP7D
If anyone is looking for a solution here, it looks like there's now an option to "remove model" which works as expected and doesnt throw a warning when exporting to fusion.
