Black window on start
MESO-DI
Message 1 of 26
MESO-DI
I'm currently getting a black window instead of the login screeen. This started happening without changing my version of Eagle (8.6). Installing 8.6.1 did not resolve the issue. Only versions prior version 8 are still working. I'm using Ubuntu 17.10.
I'm assuming this has to do with the webview component. I had similar issues with Chrome on Windows.
Replies (25)
Message 21 of 26
Deleting the files made no difference for me either.
Message 22 of 26
jorge_garcia
Hi @Anonymous,
I hope you're doing well. I've made a full report for this, stay tuned.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 23 of 26
MESO-DI
Eagle 8.7 has resolved the issue for me. No more black screen for the login window.
Message 24 of 26
Timon-MESO
This issue popped up again in Eagle 9.5 including all sub releases.
Message 25 of 26
jorge_garcia
Hello @Timon-MESO,
I hope you're doing well. Try starting EAGLE from the terminal and lets see what it reports this time. Let me know what OS and hardware you are working with. In the EAGLE installation directory you'll find a readme file. Try the suggestions in it and let me know if that helps.
Let me know if you continue to run into issues.
Best Regards,
Jorge Garcia
Message 26 of 26
I had the same problem on Kubuntu 19.10 having Intel Graphics. The problem must have been result of an update and occured first with eagle 9.5.2.
Solution is starting eagle with following shell skript:
#!/bin/sh
export LIBGL_ALWAYS_SOFTWARE=1
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0 ./eagle
Last line is necessary since several releases of eagle. Second line fixed the black screen problem.
Hope it helps,
Peter
