Adding a generic IC part
Hello. New Eagle user. Total noob question.
How do I add a generic SOIC-8 surface mount chip?  I can find generic DIP chips in the library but no SOIC?
Thanks.
one-of-the-robs
There is no such thing. An SOIC-8 package could contain a FET, a single op-amp, or a microprocessor. Which is it?
If you have an IC in an SOIC-8 package then you can make a library "device" for it using the generic SOIC-8 "footprint" (a.k.a. "package" in some places) from the ref-packages library. Or create it (and a 3D package) with the package generator tool. But...
What IC is it that you're using? What's its function? What is the schematic "symbol" for that? Eagle does not deal in randomly drawn arbitrary boards. It deals in properly designed, functional, electronic circuits, for which you need to draw a schematic first, and you need the devices you're using to mate up the appropriate schematic symbol with the correct package and pin-out.
Thanks for the reply.
The chip is Texas instruments THS7314. A widely used 3-channel amplifier. I searched in the library a lot and couldn't find it, but as my circuit is simple and already proven working I just want to get a gerber file for manufacture fast, so was just looking for a part with the same footprint.
Will I have to create every item I use unless it is a generic passive resistor or capacitor? That could become tiresome quickly!
one-of-the-robs
Widely used in the sense of "very limited application but popular with the not-very-many people designing exactly that thing".
If you're determined to just hack something together without doing the job properly, then I can see how a tool that expects you to have some pride in your work could get tiresome. However, if you actually give the library editor a chance, you'll realise that it's really easy to create library parts. It would have taken me less time to make a THS7314 device than you waited for an answer to your question. It's that easy. It's also a fundamental part of the job of an electronics designer, so learn how to do it.
Thanks again for taking the time to reply.
I am planning to learn Eagle, but I guess I naively assumed that I could jump in and create something simple, and build on the knowledge as I go. Some software packages this approach can and does work.
I'm sure that an experienced Eagle user can create parts in a few minutes, but don't underestimate the learning curve to get to that stage. I'm not an electronics engineer. I'm a DIY/hobbyist who has literally only just got access to a PCB engraver, and simply want to see what I can create.
one-of-the-robs
You can just jump in with Eagle - and design something like a guitar amplifier or a flashing Christmas tree or any of the other popular beginner electronics projects - using only the supplied libraries. However, no PCB tool will provide libraries for every part you could ever want.
The Eagle tutorials are good. They take you through creating library parts. I'm not underestimating the learning curve - I was a beginner myself, once - I'm just remembering that it really wasn't that big of a curve.
Open a new library. Create a symbol called "SIMPLEAMP". Place two pins, one "IN" and one "OUT". Draw a triangle between them. Add >NAME and >VALUE texts. Now create a second symbol called "PWRGND" with just two pins, VCC and GND. Now copy the SOIC-8 package into that library. Create a device. Add the SIMPLEAMP symbol three times, nicely laid out. Add the PWRGND symbol once. add the SOIC-8 package. Click "CONNECT" and define the pin-out. Job done. The full tutorial covers other details like pin types and add rules (whether to place all three gates at once or one at a time).
When I said I could have done it in the time it took me to reply... you could have learned to do it in the time we've been discussing it.
