9.3.0: Invoke window is hard to read
hanakp_BUT
hanakp_BUT
I've noticed a minor issue in Eagle 9.3.0 today: the Invoke window is much less illustrative than it used to be. Previously, used gates were grayed out, but that doesn't happen anymore. So the only way to tell between used and unused gates is to watch the sheet number. This should be fixed, IMO.
rachaelATWH4
Yes I agree, it was clearer before. The other difference is when you select a gate which is already placed the Ok button will change to a Show button which will take you to that gate in the schematic. But having used gates greyed out was very quick and obvious visual feedback.
Best Regards,
Rachael
