Attribute value as fields in dynamic block
leothebuilder
Advisor Advisor
Message 1 of 17
leothebuilder
I am trying to create a matchline that has an attribute for the drawing sheet number.
I tried to insert a field with the attribute value which would array along the length of the matchline as it is being stretched.
The problem is that the fields will not update as long as they are within the dynamic block.
Is there a workaround for this?
Replies (16)
Message 2 of 17
ojuris
hi!
there is a problem with update text (field is defined inside block editor) with value of attribute (value defined outside of block editor)
I add file, but if you copy block in your drawing - all texts will change ar 1st block attribute
https://dl.dropboxusercontent.com/u/401581/Matchline%20dynamic%20block-1.dwg
Message 3 of 17
leothebuilder
Thank you....that worked.
I am just curious how you got it to work, can you explain.
Message 4 of 17
ojuris
  1. add attribute in your block (after all can delete)
  2. gou out of block editor mode
  3. add to new attribute field (value of the other attribute) and copy Field expression (look at picture)
  4. go into block editor mode and in Text copy this Field expression
  5. delete unnecessary attribute
Message 5 of 17
leothebuilder
Got it...thanks again.
Message 6 of 17
leothebuilder
There's just one flaw I just discovered.
If I copy the block in the same file and change the attribute of the copy, it still displays the value of the attribute of the original block.
E.g. the fields in the copied block displays the value of the original attribute.
Message 7 of 17
ojuris
I wrote that in my 1st post  🙂
Message 8 of 17
leothebuilder
Sorry...yes, you did mention that. No workaround I guess...
Message 9 of 17
ojuris
are you going there to write something fixed or every time something completely different?
Message 10 of 17
Libbya
I do not know of any way to have a 'preset' field that can be both arrayed and user-edited.  A way may exist, but I've looked and come up dry.
I imagine your matchline is going to be used on 'paper' and so there is a practical limit to the length.  If so, then the 'easy' solution is to use visibility states, attributes and a double lookup to simulate the array.  I'd also always want the text at each end of the line and then evenly spaced between as new ones were added.  See attached.
Message 11 of 17
leothebuilder
I probably will have several match lines in model space to separate clipped xrefs.
One workaround I have is to make 5 or 6 separate dynamic blocks.
Message 12 of 17
leothebuilder
Your solution is nice and clean. Thanks.
I do normally use these in model space.......with several clipped xrefs.
Message 13 of 17
Libbya
When I said 'paper' I was not specifically talking about whether your drafting technique was to use the block in model vs. paper space.  Instead I was saying that there is a practical limit to the number of necessary occurrences of the text: you don't need an infinite array so the visibility states/lookups will work fine.  There's no problem using it in model or paper space.  If the block is used on architectural drawings, the 3/32" text height is appropriately readable, but much smaller than that would not be.  On Arch E, if you are using that block with text height of 3/32, the # of occurrences of the text if diagonal on the page and spaced at 5" apart would be a total of 12 (hypoteneuse of 55").  If you wanted more occurrences than the 5 I supplied, you could add the appropriate visibility states and lookup values.
Message 14 of 17
leothebuilder
Got it....thanks
Message 15 of 17
marcosmendez
I'm using this example to crate a scalebar.  How did you get the SHEETNO attribute created?
I am using the ATTDEF or Attribute definition button.  I don't know how to add an attribute like the SHEETNO.
Message 16 of 17
jarredmonday
@marcosmendez If you zoom in real close to 0,0 there is an attribute with its TAG SHEETNO and its value is A100. It is really small and hidden behind the line.
To answer your question...you'll make another attribute like you normally would.
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Message 17 of 17
marcosmendez
I created something for a scalebar, and it works, but when I insert it into another drawing, I have to open it in block editor, then save the block, but it works.
