Good morning, please see attached file (AutoCAD 2016). I was ablle to make dynamic blocks before. But now, even if I placed an action, the yellow mark still there and the grip won't show in the test mode.
Solved by Imui. Go to Solution.
yup.
There's something wrong with the stretch action. Just replace it.
Something got mixed up in the parameter set.
The correct action should be Stretch - End point. Stretch - Start point.
Here's the problem recreated on the left
Thx.
In the process of making stretch, I though the red cross with circle symbol was the base point. Actually, it needs to be the stretch point which to be associated with the action. That's why I made the mistake. Didn't make dynamic blocks for a long time, totally forgot it.
