I am trying to create a block for one style of window to use for the elevations in our drawings. Currently, the block we have has Lookup properties so you're able to select a width THEN a height. The issue with this is if a 3056 (width & height) window is drawn with this block, we may not have it in stock, so what I'm trying to do is set it so you can select 3056, 2460, etc. from one Lookup action rather than select one then the other. Also, we like to show the window size along with whether it's an equal/oriel sash within the window itself so that it's clearly visible on the elevations. I'm pretty sure the window size & sash note needs to be defined by an attribute definition for it to mirror correctly without flipping the text.
I've given it my best shot and when inputting all of the dimensions into that single lookup parameter, the tab to select the size disappears when testing the block. Also, I can't seem to figure out why the "sash" note won't appear either.
I've attached the file for anyone willing to help out. I greatly appreciate any help anyone has.
Thanks!
