I've been using Autocad with dynamic block to create different elements.
Now, I'm trying to use a spline in a dynamic block.
My spline is defined by 4 points:
- 1 starting point fix
- 1 end point fix
- 2 vertex points.
I know the position of all these points. I can easily draw the spline in the "model space" of Autocad. My problem is that I do not know how to put constraint and dimensions on the 2 vertex points in the dynamic block.
Maybe, it is not possible?
I have also tried to use the "smooth" function, it works well to define the orientation of the tangent, but it doesn't allow controling the geometry of the spline totally.
(I'm using Autocad 2015)
Thanks for your answer.
Simon
