hello everybody,
first time posting a problem here so if i'm missing information please feel free to ask.
When I import this dynamic block a co-worker made and I try to snap it to the center of this circle (radius 5) it turns off the o-snap and some lines are highlighted. Also it flips the block horizontally. There is no function in the block that does that. When I try to snap the block to the center of a circle with another radius (radius 10) it works normally and this wont happen. I think it had something to do with that the block is drawn with a standard radius of 5. Because it only occurs so far when it is place on a circle with a radius of 5.
I recently switched to autocad 2024. i never had this problem with older autocad versions
I am working in the full autocad version.
is there a setting i can change so this will not happen anymore?
Solved by h_s_walker. Go to Solution.
At the command line type AUTOPLACEMENT. Change the variable to 0.
See the link below for how smart blocks work
AutoCAD 2024 Help | Smart Blocks: Placement | Autodesk
Howard Walker
