Visibility State and Send to Back question
If you make a dynamic block with multiple Visibility States... and each state has a few color hatches or lines that are supposed to be in the background... Is there a way to make sure the "Drawing Order" "Send to Back" or "Bring to Front" continues to works?
Attached is a slimmed down example... In it, I can use test block in the block editor and the Drawing Order is correct when switching between the versions... But when I start a brand new drawing file and insert this same block, the Drawing Order is not showing as before... Regen doesn't seem to help either.
my goal is to make these lines stay in the back so the actual white/black lines stay in front so they print in front. (currently printing shows them wrong too.)
Inventor: Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
