I have a block for a duct riser, it has 6 visibility states associated with it
I would like to be able to scale it in the X axis a dimension and the Y dimension with different distance (12x18, 18x24 etc)
I started out using a generic block full size @ 6"x6" applied all my geomery to accomadate the visibility states needed.
when i set the stretch X axis the hatch does not play nice and same for Stretch Y axis.
any ideas , i am sure I am missing something along the way.
any help is appreciated
thank you
Solved by Libbya. Go to Solution.
Solved by kadmonkee. Go to Solution.
I have attached the example block of what i am attempting
I would like to have this flexible in all visibility states in both the X and Y axis independently
(12x18, 24X36, 32X18 etc)
Attached is a screencast that shows how to do what you would like. If you would like specific sizes, add a lookup and the necessary values to control the two linear parameters.
