- Mute
- Permalink
- Report
I work in autocad electrical but creating a dynamic block to use. As shown in the dwg attached, I have a dynamic block with visibility and Point Properties added to cycle through base points when inserting. If I re-insert the block into the same drawing (NOTESTESTING) I can use the CTRL key to cycle through those points (even without action assigned to those points). I have done this and used before in other things a while ago just fine.
If I insert the NOTESTESTING into a new drawing I cannot cycle through those points. I am still trying to figure this out, I tried a solution changing LEGACYCTRLPICK but that does fix.
Thank you for the help
