Using a Stretch Action after a Rotate Action
I have noticed that I get wierd behavior when I rotate my block, and then try to use a stretch action.  Attached is an example file.  I am trying to get the triangle to stretch as well as rotate.  The stretch functions work correctly if I don't rotate the block, but as soon as I rotate, the stretch actions behave incorrectly.
ojuris
hi!
don't include stretch actions in rotate action
do it only then when you really need it
Libbya
It is because you are rotating BOTH the stretch actions AND their associated linear parameters.  When you rotate a stretch action, you change its angle offset.  If you are rotating the associated parameter and the angle offset is 0 and should stay 0, then rotating the action also will skew the stretch as you see.
