Dynamic Blocks Forum
Updating parameter is very slow (compared to attribute)
0 REPLIES 0
Message 1 of 1
WF.Con
152 Views, 0 Replies
Hi all, and thanks for reading in advance
I've recently switched from using attributes to parameters for input.
This way they're separated in the properties bar (from the static attributes), and easier to see which properties should be filled in by the user.
However, when I edit multiple blocks' parameter (say 100 or so) it takes autocad a lot of time to process this.
Whilst the attributes are almost instantly updated.
Anything i'm missing? Or is this just the way parameters work?
it's almost as if for updating a parameter, autocad has to go through a lot more steps.
edit: see attached a block, array it x100  and  use "select" to change it (blocktable)
0 REPLIES 0
Forma Design Contest
