Update Field with attributes in Dynamic block & Block
hello all
I attached an example to show you my problem with updating filed with attributes values in blocks and dynamic blocks
there two blocks the first just is a block (test1) with 4 attributes, one of them call tag has a field reading from other attributes value. this block doesn't updating itself to show key and unit attributes value.
the second block (test2) has the same 4 attributes but it contains a visibility with two states, if I insert this block form insert block command and try two change the key and unit attribute, tag attribute doesn't update, but if I change the visibility state the field will work fine.
so my questions now,
1. why in the first block (test1) field doesn't work?
2 why in the second block (test2) field doesn't work after insert directly without change visibility state
any solution to this problems?
