Update Field with attributes in Dynamic block & Block
Amremad
Amremad
hello all
I attached an example to show you my problem with updating filed with attributes values in blocks and dynamic blocks
there two blocks the first just is a block (test1) with 4 attributes, one of them call tag has a field reading from other attributes value. this block doesn't updating itself to show key and unit attributes value.
the second block (test2) has the same 4 attributes but it contains a visibility with two states, if I insert this block form insert block command and try two change the key and unit attribute, tag attribute doesn't update, but if I change the visibility state the field will work fine.
so my questions now,
1. why in the first block (test1) field doesn't work?
2 why in the second block (test2) field doesn't work after insert directly without change visibility state
any solution to this problems?
ojuris
Currently, this is the way dynamic blocks work. I mean the situation when you after inserting block must take same dynamic action (after my experience - any action) and then fields in attributes are working as expected.
I don't like this situation. But I do not see another solution at this time.
About 1st question - fields does not work because you don't make any dynamic actions in this block (you even don't have).
And don't forget to check "Display value for block reference" when create field in attribute.
