Unable to see or find certain stretch action frames in this block. HELP!
pete592
pete592
I need to edit the attached block, but I cannot see the stretch frames for the Stretch2, Stretch3, Stretch4, and Stretch5 actions.  I can see the Stretch1 and Stretch2 frames just fine.
Does it do this for anyone else?   Any idea what could be happening here?
Thanks in advance.
Pete
rapidcad
Hi Pete. Just select each visibility and eventually you will come across the one that the stretch window was defined in. You have to zoom in on the FlangeID (upper end) because it is quite small. They are all there.
Visibility states can hide those from you even if you turn on BVMODE.
HTH,
Ron
ADN CAD Developer/Operator
rapidcad
Hmm, I just looked at your OP again and I just realized you might have uploaded the wrong block, but nonetheless, I think your problem is the same in either - check all the visibilities and highlight the actions you are searching for.
pete592
Thank you!
