Stretching Equilateral triangle in dynamic blocks
wael6URAQ
wael6URAQ
I need  to create A dynamic block which allows to stretch an equilateral triangle by 1 grip of one of the equal sides and a user value for third side.
I managed to create this using Constraints but I need to create it by parameters but it didn't work
can any one help.
Libbya
An equilateral triangle has three equal sides.  An isosceles triangle has two equal sides.
I don't think that can be achieved using only dynamic parameters/actions and operate in the way you describe.
wael6URAQ
sorry my mistake it is an isosceles  triangle but you know what I mean :).
Ok If So
Is there a way to coincide dimension line to move with the constrained lines??
h_s_walker
You will probably need to use dimensional constraints as the shape of the triangle which change depending on what your base length is. See the image below
Howard Walker
Left Handed and Proud
