Table inside block not reading inserted fields
coffeejeanpaul
coffeejeanpaul
Good day.
I am looking to make a dynamic block, inside the block I want to place a table to read the set values of actions and block locations inside this block.  When I do the normal insert field it works perfect inside the block. Once I save it it all gets lost and does not update according when using the dynamic block.
Basically I am try to simulate a crane block  : Height from 0,0     : distance from 0,0 and wire length from the action.
I am not to clued up if I am using the correct method to read the values, I would like to keep a table inside the block.
Any input would be super useful.
alexandru.alexeN6U84
hi,
that error will is becouse object modification causing reference loss. i do not know  how to help you, but i do not understand you you need table in bloc.
if you need that table move whit the line, you can apply some constrain.
j.palmeL29YX
Your table shows two values ("Boxheight from 0,0" and "line length"), the geometry shows one value ("Distance1") and you ask for three values ("Height from 0,0", "distance from 0,0" and "wire length").
I guess that Distance1 is the wire length (?), but what/where are the others?
Can you show us a small sketch please so we can see what you want to achieve.
Jürgen Palme
