Dynamic Blocks Forum
Table and visibility states
2 REPLIES 2
S_S_SS
390 Views, 2 Replies
Hello every one
i have more and more visibility states and i want to make a table
when i try t add parameter in the table i can't see the visibility state
why that happen ??
i use visibility states in lookup parameters is that the reason of this problem ??
i attach the drawing in below
and thanks in advance
Tags (3)
2 REPLIES 2
akhtar4223
in reply to: S_S_SS
i use visibility states in lookup parameters is that the reason of this problem ?? YES THIS IS THE REASON.
I REMOVED IT FROM BLOCK, NOW 'VISIBLITY STATE' SHOWS UP IN TABLE.
S_S_SS
in reply to: akhtar4223
thanks about that
AutoCAD Inside the Factory
