Good Morning,
The Company I work for does not use sheet sets or vault but inserts an attributed Title block for each new project. I prefer to use a template file where my drawing properties fields are already customized, but am looking for a way to use fields in their block. Upon insertion the fields loose all data and the dwgprops no longer show the customizated fields. Any help?
SuliHawk
Solved by Charles_Shade. Go to Solution.
Welcome to the Autodesk Forums!
...Upon insertion...
I'm assuming you have a Block that has Fields and then you are inserting this Block into a new Drawing?
If yes then the Fields are not associated with anything. Add this Block to your Template and update the Fields as needed and then use the Template.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thank you. The older drafters here are just not template broken yet. I will work on them.
